Activity Forums Adobe After Effects Expressions Multiple expressions on brightness parameter
  • Multiple expressions on brightness parameter
    Posted by Ryan Metcalf on July 9, 2014 at 7:05 pm
    Hey all,
    Im trying to manipulate a lens flare (with added elements) by attaching parameters to null object with sliders. Im running into trouble when I try to put multiple expressions on the flare brightness, the latest expression will only work.
    I wanted one to control the master brightness and the other two sliders to control the wiggle frequency and amount. They work independently fine, but when added together I run into problems.
    Any help would be much appreciated.
    Best,
    Ryan Metcalf
    thisComp.layer("CONTROL").effect("Brightness")("Slider");
    wiggle(thisComp.layer("CONTROL").effect("Flicker Frequency")("Slider"),thisComp.layer("CONTROL").effect("Flicker Amount")("Slider"))
    Dan Ebberts
    replied 12 years, 2 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    July 9, 2014 at 7:49 pm
    I’d try it this way:
    f = thisComp.layer(“CONTROL”).effect(“Flicker Frequency”)(“Slider”);
    a = thisComp.layer(“CONTROL”).effect(“Flicker Amount”)(“Slider”);
    w = wiggle(f,a) – value;
    thisComp.layer(“CONTROL”).effect(“Brightness”)(“Slider”) + w
    Dan
