Activity Forums Adobe After Effects multiple emmiters for particular
  • multiple emmiters for particular
    Posted by Craig Hellen on January 1, 2008 at 10:18 pm
    I was following a tutorial for particular by trapcode and I was using a light as the emitter for the particles and it was working really well. I want to have more than one emitter, it doesnt allow you to select different lights and when I try using a layer I cant get it working,
    anyone able to shine a little light on this?
    cheereo
    Fredrik Nilsson replied 18 years, 8 months ago 4 Members · 4 Replies
  • Sam Moulton
    January 2, 2008 at 12:03 am
    You have to use multiple layers with a different emitter for each instance
  • Don Sciore
    January 2, 2008 at 12:11 am
    Can’t you pre-compose a layer>add another instance of Particular and new lights in the precomp and get the result you want in the main Comp?
    Worth a try.
    Good Luck.
    Don
  • Craig Hellen
    January 2, 2008 at 12:35 pm
    ah ok i cracked it thankyou, now i just have to work out how to colour them differently, tried using 2 adjustment layers placed in the layer hierarchy but that didnt work grr! hehe
    all the best,
    craig
  • Fredrik Nilsson
    January 11, 2008 at 7:26 pm
    You can use several lights as emmiters as long as you name them Emitter1 Emitter2 and so on.. then you can change color by changing color of the light in the light option
