Activity Forums Apple Final Cut Pro Legacy multiple effects
  • Neil Patience
    January 26, 2012 at 8:59 pm
    Once you have one clip with an effect that you are happy with, select that clip and use the option c copy command.
    Then de-select your first clip and select all the other clips you wish to apply the effect to.
    Right click and select the “paste attributes” option.
    This will bring up a dialogue box with various options.
    Select the “filters” option and click OK
    That will apply the effect from your first clip to the rest.
    best wishes
    Neil
    http://www.patience.tv
