Activity Forums Adobe After Effects Multiple drives for working in AE
  • Multiple drives for working in AE
    Posted by Jon Simpson on October 24, 2020 at 1:24 pm
    I just bought a new laptop and it only has 2 SSD slots. On my desktop I use 3 different drives, one holds all of my project files in my Dropbox folder that continuously updates between both the desktop and laptop as I switch working between the two. The 2nd drive is for all of my cache folders for AE, and then of course, the C drive that AE is located on.
    My question is what would be the best approach with only 2 drives to use? Should I put my Dropbox folder on my C drive with AE and the cache folders on the 2nd drive? OR should I put the Dropbox folder AND the cache folders on the 2nd drive? OR, the Dropbox folder on the 2nd drive and the cache files on the C drive?
    Thanks if you have any suggestions!
    Walter Soyka replied 5 years, 10 months ago 4 Members · 3 Replies
  • Eric Santiago
    October 24, 2020 at 9:17 pm
    You don’t have any type of USB3 or Thunderbolt connection?
    Its always best to keep the three separate.
    I use two, local RAID and network server.
    For Cloud, I have Dropbox, frame io, and Media Share.
    I rarely sync cloud files to local.
  • Michael Szalapski
    October 26, 2020 at 12:10 pm
    I always keep my cache on a drive that’s dedicated to the task. I want the cache to be as fast as possible, so I don’t want anything else writing or reading from it when I’m working in AE. (I use the same drive for caches for X-Particles and other software too since I’m not using those while I’m also using AE, so the drive gets use for multiple software – just not simultaneously.)
  • Walter Soyka
    October 27, 2020 at 4:41 pm
    Do you know how your SSDs connect internally? There’s a big performance difference between NVMe/M.2 and SATA.
    Your cache should be on your fastest drive. If you have an NVMe drive, I’d put the cache there — even if it’s also your system drive.
