Activity Forums Apple Final Cut Pro Legacy multiple default transitions
  • multiple default transitions
    Posted by Peter Ralph on June 30, 2006 at 11:46 pm
    is there a way to apply alternate default transitions, so that I can apply a 4, 6 or 8 frame dissolve dissolve each with one keyboard shortcut.
    it’s kind of laborious to go in to effects and change the default transition manually each time. Or is there an easier way of changing the default transition?
    Julio Alvarez replied 14 years, 8 months ago 3 Members · 5 Replies
  • Shane Ross
    July 1, 2006 at 3:41 am
    Yes.
    Add a dissolve to a cut, then double click on it and make it as long as you want. Then drag it from the Viewer into your FAVORITES folder.
    Then go into the Custom keyboard setup and map FAVORITE TRANS #1, #2 and #2 to whatever key you want. Almost all my F-Keys are mapped.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Peter Ralph
    July 1, 2006 at 5:54 am
    nt
  • Shane Ross
    July 1, 2006 at 9:04 am
    nt?
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Peter Ralph
    July 1, 2006 at 1:00 pm
    no text
    ;O)
  • Julio Alvarez
    January 16, 2012 at 7:37 pm
    You rock Shane.
    Quick way to Customize Keyboard Layout:
    Tools/Keyboard Layout/Customize
    or
    OPT+7
    Jx
