Activity › Forums › Adobe After Effects › Multiple custom exports
  • Multiple custom exports
    Posted by Stuart Clark on September 21, 2018 at 3:02 pm
    I’ve got a project whereby I need to create more than 200 very slightly different versions of the same video in After Effects. They’re essentially personalized e-cards, so the only difference is an altered text layer at the beginning that introduces the video to each different person its being sent to.
    If I have to, I’m going to need to work through this, manually changing the text layer each time then sending it to export… pretty boring and time consuming (and I hope needlessly so).
    It so happens that I have all the names I need for this on an Excel spreadsheet. So, I wonder if there might be a way I can automate a batch render to create the requisite versions of my composition by somehow pulling the text information individually from each Excel cell and pasting it into the text layer each time. Then I’d be able to batch export the whole lot and spend the rest of the time with my feet up with a cup of coffee rather than getting a migrane and feeling the joy drain from my very being from the repetition!
    I wonder whether there might be an script or function etc that could do the job? Any suggestions much appreciated!
    Diego Gonzalez replied 4 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Blaise Douros
    September 21, 2018 at 4:07 pm
    https://forums.creativecow.net/thread/2/944530#944546
    Check out this old thread and see if it helps.
  • Walter Soyka
    September 21, 2018 at 5:58 pm
    Check out CompsFromSpreadsheet:
    https://aescripts.com/compsfromspreadsheet/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Stuart Clark
    October 12, 2018 at 11:13 am
    Many thanks, this was very helpful
  • Stuart Clark
    I think we may invest in this script, thanks for the link!
  • Diego Gonzalez
    February 3, 2022 at 5:25 pm
    Thank you Walter,
    I am familiar with CompFromSpreadSheets, but in my case since I need to share the project with users that wont be able to purchase this script and also consider I just need to rename the main Comps based on a spreadsheet. My understanding is that there is no way to do that within After Effects, since this operation has to be done trough an Extendscript. Do you think there’s a way may be to do it trough expressions?
    Thank you so much for your help,
  • Walter Soyka
    February 4, 2022 at 12:17 am
    Expressions can only affect the values of stopwatch-able properties. They can’t perform user/GUI actions like renaming items in the project panel.
  • Diego Gonzalez
    February 4, 2022 at 3:40 pm
    Thank you for clarifying, Walter!
