Activity › Forums › Apple Final Cut Pro Legacy › Multiple codecs issue
  • Multiple codecs issue
    Posted by Rick Pratt on March 23, 2011 at 3:38 am
    So I am posting a movie that was shot on four different cameras with 4 different codecs – h264, XDcam, DVCPro HD and ProRes 422 (HQ). The initial idea was to convert all to ProRes 422 (HQ) and then merrily go about our day. Now I am discovering that the XDCam and DVCPro HD footage all playback pretty nicely in a ProRes sequence. I’d love to not have to spend the time converting the XDCam and DVCPro HD footage to Pro Res, but am I going to run into issues at the end of the post process, such as anomalous glitches and render problems due to the mixed codecs?
    Chris Borjis replied 15 years, 6 months ago 3 Members · 2 Replies
  • Chris Tompkins
    March 23, 2011 at 11:48 am
    If it continues to play fine and you can edit, it’s worth a shot.
    When you do a final RENDER ALL though, it will compress to the codec of the sequence.
    Chris Tompkins
    Video Atlanta LLC
  • Chris Borjis
    March 23, 2011 at 4:09 pm
    As long as the framerate is the same it should work quite well.
    Set the render codec in the sequence setting to ProRes for best results.
