Activity Forums Adobe Premiere Pro Multiple Clips w/ Audio
  • Multiple Clips w/ Audio
    Posted by Jay Shelton on April 28, 2014 at 5:03 pm
    I have a several interviews that have two angles and I’m trying to drop all the clips into a single timeline and have them sync up but PPCC won’t allow me to do so. It appears it will only try to sync two clips at a time. I prefer to keep the video tracks stacked VS multicam.
    Untitled Document
    Jeremey @ LinkedIn
    Steve Crook jr replied 12 years, 4 months ago 2 Members · 1 Reply
  • Steve Crook jr
    April 29, 2014 at 2:51 pm
    Hi, Jeremy!
    I’m not entirely sure what you are asking, but I THINK you want all of your video captures (I’ll not call them clips here, because that term has specific meaning in PP) from different angles lined up one atop another in a sequence timeline. From there you want to be able to adjust their position in the timeline – ideally, having PP sync them together for you.
    Assuming that is what you are after, here is what I do when I need the same thing.
    1) I take the video captures and combine them into one sequence for each angle as I describe in my first answer in this thread:
    https://forums.creativecow.net/thread/3/953347
    basically this takes all of the 4Gb + last files of the capture, turns them into PP clips, combines the clips into a sequence, then turns that sequence into a clip for another sequence.
    2) When I’m finished with all of the angles (BTW, I usually just use two, but sometimes I get some footage with my cellphone, too), I create a new sequence, drag all the angle sequences in, then sync the AUDIO as I describe in my second answer to the above thread.
    3) Once the audio is synced, I realign each audio track’s video to line up and then edit my sequence.
    I hope this helped, if I didn’t explain something properly (my brain takes shortcuts sometimes 🙂 ) let me know, and I’ll try to help.
    Steve
    Steve Crook, Jr.
    http://www.stevecrookjr.me
    I am a simple creative professional that can get my Adobe suite and a few other creative tools to do what I want. Barely. 🙂
