Activity Forums Adobe Audition Multiple clips into multiple files
  • Multiple clips into multiple files
    Posted by Mike Bernard on July 4, 2018 at 1:38 am
    I have 40 or 50 individual clips that I need to edit a bit ( taking out pauses and false takes ) and then master ( they are all from the same voiceover session ) and then export as individual clips. I’m thinking of making a multitrack session,, working on each clip, having them all run through the same master effects and then just soloing each track and exporting them one at a time. Any of you bright cats see a more efficient method through this ?
    Mike
    Simon Billington replied 8 years, 2 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    July 4, 2018 at 7:46 am
    I don’t know how if it is much better than your approach, but you can make the effect settings you want in the first track, save as preset and then assign them to each track. You can then export multitrack as individual tracks upon export in one go. I would try with a couple of tracks first to see if there’s anything to be gained that way.
    Senior Graphic Designer
  • Simon Billington
    July 26, 2018 at 2:58 am
    Well given they are from the same voiceover session, you may not even have to go that far, unless you have different voices.
    In this instance, I’d try to get away with using one track. Adjust any individual clip volumes if necessary, but only top to around +/- 3dB, as they are the same session and should be pretty close any way. Then I would process them all together. Denoise, eq, compress limit, that kind of thing.
    You could then export them as one long region and splice it later in your editor, or go through the painful task of doing one by one.
