Activity › Forums › Apple Final Cut Pro Legacy › Multiple clip speed change
  • Annaël Beauchemin
    August 3, 2006 at 4:55 pm
    yep.
    Do you speed change to one clip, select it, copy it (command-c OR right-click -> copy).
    Then select all the clips you want to apply the speed change to, paste attribute to them (option-v OR right-click -> Paste Attributes), select “speed” in the Paste Attributes box and hit ok.
    voil
  • Solid Porcupine
    August 3, 2006 at 5:03 pm
    You’ve saved me hours.
    SP
