Activity Forums Blackmagic Design Multiple Clip Playback
  • Multiple Clip Playback
    Posted by Jonathan Penzner on May 16, 2005 at 5:48 pm
    Curious if I can play back multiple clips seamlessly on my Decklink SP video screen.
    Here’s the scenario: Ideally, I’d like to take one long video clip and play back sections at a time, pausing between sections. If I can’t do that, then I’d break the long clips into as many shorter clips as necessary, but seamlessly go from one clip to the next.
    If FCP had some facility for pausing at a marker, that would be ideal. But is there some program out there that will accomplish the same thing?
    I used to do this in Macromedia Director but for some reason I can’t get the stage to work on the Decklink Video screen. In any case, I’m about done with Macromedia (unless Adobe makes it worth looking into again) so I’m looking around for something easier to use that will also play on the Decklink Screen.
    TIA
    Jonathan Penzner
    Sundance/Realtime
    (626) 345-0285
    sureal@charter.net
    Jonathan Penzner replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
