Activity › Forums › Blackmagic Design › Multiple BlackMagic Intensity Pro Cards in a single i7 PC
Greg Sullivan replied 14 years, 8 months ago 9 Members · 13 Replies
Brian Daly
August 10, 2010 at 11:23 pmDan, I used a 3 way HDMI Switcher connected to one of my Intensity Pro cards and connected remaining Camera directly to the other Card. I also use HDSDI HDMI Mini Converters for longer runs with a 4 way HDSDI Switcher. I record using On-Air 2 so I can switch and monitor the other Camera’s before I change over in On -Air 2
Brian Daly -
David Kadlec
September 27, 2010 at 2:37 pmBrian,
You mention you use a 3 way HDMI switch. Is this the inexpensive type switch commonly used for hooking up multiple HDMI devices to a TV? If so, are there any HDCP handshaking issues associated with it? For instance is the switching instantaneous?
Greg Sullivan
January 11, 2012 at 7:38 pmDan I’m also needing to build a system with 3 active HDMI inputs.. Did you ever get this working? (Or anyone else)
