Activity Forums Apple Final Cut Pro Legacy Multiple Audio track export and Import question.
  • Multiple Audio track export and Import question.
    Posted by Phil Bucci on February 14, 2014 at 2:06 am
    Hi I have just received my dual mono audio splits for my project. I am able to export the multi track qt but when I reimport the clip to check the work any track I panned L or R are back to center. Does any one know why the new clip does not retain the panning? I have the sequence settings > audio outputs > set to dual mono. Everything is on the correct track so I thought I had everything set correctly.
    Thanks for the help
    Shane Ross replied 12 years, 7 months ago 2 Members · 1 Reply
  • Shane Ross
    February 14, 2014 at 7:20 am
    You said it yourself…you have the sequence set to dual mono. If you want it panned, make it stereo.
    Shane
    Little Frog Post
