Activity Forums Adobe Photoshop Multiple Alpha Channels question
  • Multiple Alpha Channels question
    Posted by Jon Herron on February 16, 2006 at 11:30 pm
    Sup guys,
    I have a quick question about a PSHOP document containing three different alpha channels. So right, I have three different alpha channels each masking a different section of the screen when needed. The “save” file needs to be a TARGA file saved at 32 bit to of course hold the alpha channel. Now when I save the file with the desired alpha channel(out of the three in the channels palette) as a TAGRA it does not take the channel. If it is saved with only one alpha in the pallette(not three, I deleted the other two) it of course holds the channel. Pheww, now is there a way save a targa and get the alpha channel I want without always adding and deleting channels?
    Jon Herron replied 20 years, 7 months ago 2 Members · 4 Replies
  • Richard Harrington
    February 17, 2006 at 12:16 am
    Nope…. Targas and Picts only recognize first alpha channel
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Jon Herron
    February 17, 2006 at 2:36 am
    Ahhh….I see. Thanks. On another note. Is it possible to merge two alpha channels? -the HELP says they need to be two different grayscale images with alpha channels- true??
    thanks for you help
    jon
    February 17, 2006 at 2:43 am
    Two different ways
    calculations command or
    Cmd click on one, then shift md click on other… then click new channel button to create a channl using current selection
  • Jon Herron
    February 17, 2006 at 9:13 pm
    Cool thank you Richard!
