Activity Forums Maxon Cinema 4D multipass render failing every time
  • multipass render failing every time
    Posted by Neil James on September 20, 2005 at 7:38 pm
    I am trying to render a multipass with two objects using compositing tags and image buffers – to get seperate alpha movies.
    Ive used this method before and its been fine. But – i keep getting the message – ‘unable to write file’.
    Ive tried copying and pasting into a new file, re routing the file paths – nothing works. When I switch multipass off the movie renders fine.
    Any ideas?
    Lennart Wåhlin replied 21 years ago 2 Members · 1 Reply
  • Lennart Wåhlin
    September 20, 2005 at 9:08 pm
    For me, 9 times out of 10, this happens if the result is in use anywhere. Either opened in another program or if active in Finder (I’m on Mac) and thus used
    by Finder for previewing the file.
    Cheers
    Lennart
