Activity Forums Maxon Cinema 4D multipass for separate objects
  • multipass for separate objects
    Posted by Tatra Tero on August 2, 2011 at 11:16 am
    Hello,
    lets say that i have a box and a sphere, the box have a red color,the sphere have different color,both have a different material. how can i use multipass to have each object its own output in Photoshop ,so i can adjust the color or the material of the box individually without affecting the sphere material .
    with lot of thanks
    Tatra Tero replied 15 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 2, 2011 at 1:43 pm
    First you have to give each object a compositing tag. Then, in the tag’s Buffer tab, asign each object a unique number. Next, in render settings>multipass, add two buffer passes with the corresponding numbers.
    Cinema will then render out an alpha for each object which you can use as a luma matte in AE.
  • Tatra Tero
    August 3, 2011 at 9:36 am
    thank you Adam Trachtenberg your reply help me alot
