Activity Forums Adobe Premiere Pro Multimframe single audio source
  • Multimframe single audio source
    Posted by Darren Lee on September 27, 2016 at 9:58 am
    I have a Multi-cam sequence with 4 tracks of footage (and audio) within it, but I only want to use the audio from 1 of the tracks,.
    At the moment, I’m having to unlink the audio, and duplicate it 4 times so that it replaces each of the other audio tracks, so that when I switch camera angles it uses the correct audio
    Is there a better way of controlling this?
    Using CC 2014
    Darren Lee replied 9 years, 11 months ago 1 Member · 1 Reply
  • Darren Lee
    September 27, 2016 at 2:15 pm
    I’ve noticed that if I switch camera views in the Program monitor, with ‘Audio follows Video’ disabled works the way I want it to – It doesn’t switch the audio.
    The problem was that I was using the Keyboard shortcuts 1, 2, 3 etc… to switch the camera in the editing panel, it switches the audio too
    So I guess my question is, Is there anyway to disable ‘Audio follows Video’ when using the keyboard shortcuts?
