Activity Forums Adobe After Effects Multicore rendering freezes at “Initialising background processes” CS6
  • Multicore rendering freezes at “Initialising background processes” CS6
    Posted by Bart Winckers on December 7, 2012 at 11:31 am
    Hello,
    has anyone found a solution for this problem yet?
    I’m really hoping they this in an update, because it is becoming an expensive bug, with render times going op 6x.
    The interesting part is that it only freezes in certain projects, yet it has has nothing to do with 3rd party plug-ins as far as I can tell.
    I found out the problem is project based not composition based. Importing the project in to another project doesn’t work eather.
    Also playing around with the multicore rendering setting does not make a difference.
    Thanks.
    Josh Peters replied 13 years, 7 months ago 4 Members · 3 Replies
  • Tudor “ted” jelescu
    December 7, 2012 at 2:30 pm
    It is best if you add your system specs, AE version and OS to the issue you are posting about. There are a number of possible reasons for the problem you describe, but without details it’s hard to narrow it down.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Tom Daigon
    December 7, 2012 at 9:07 pm
    I experience that on my PC when trying to use Multi Processing when using VCP Element. So I dont. 😀
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Josh Peters
    February 1, 2013 at 5:45 pm
    Not sure if this is just my system, I can always get it to render out one piece then it will start freezing up. If you shut down the program there will be once after effects process that sticks around in task manager. Close that out restart the program and it will render another timeline out. I know this is obnoxious but for me anyways it still saves a ton of time.
