Activity Forums Maxon Cinema 4D multicolored mograph text
  • multicolored mograph text
    Posted by Ben Rollason on September 27, 2010 at 6:37 pm
    Hi All,
    I’m trying to make a piece of mograph text in which each letter is a different color (1 of 4).
    I’ve been able to use the random effector and a material with the mograph multishader to achieve this with a normal cloner, cloning a grid of cubes, but when I apply the same procedure to a mograph text object, it doesn’t work.
    I have the feeling I’m missing something obvious.
    Thanks if you can help.
    -Ben.
    vfx.benrollason.com
    Ben Rollason replied 15 years, 12 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 27, 2010 at 7:22 pm
    This works in R12 but it did not work in previous versions. I don’t know if it was classified as a bug or a limitation.
  • Ben Rollason
    September 29, 2010 at 7:30 am
    Thanks Adam. That’s good to know.
    Is there any kind of workaround for versions below R12?
    -Ben.
    vfx.benrollason.com
