Activity › Forums › Adobe Illustrator › Multicolor Gaussian Blur
  • Vincent Rosati
    March 14, 2014 at 8:53 pm
    You’re much more likely to get a response if you use a real name. I’m not sure if this is still in the TOS, but the COW policy has been that real names are required, no handles or spam-type names. They changed this maybe about 4 years ago.
    I used to be ‘Vintendo’.
  • Jimmy Afterglow
    March 14, 2014 at 9:56 pm
    My real name is Jimmy Afterglow… problem?
  • Vincent Rosati
    March 15, 2014 at 2:05 am
    The attached files illustrate two approaches to this:
    1 – Gradient Mesh
    2 – Blend
    Blend options (CS4)
    7235_gauscs4.ai.zip
    Blend options (v.10)
    7236_gausv10.ai.zip
    You’ll see two versions of the Blend approach. The lower resolution/stepped version is simply to show how you might reduce your CPU processing needs while testing. It is the same artwork, but with a lower step value in the blend.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Jonathan Ziegler
    March 18, 2014 at 4:48 pm
    In Illustrator or Photoshop, it should be pretty basic. I would think it would take a few seconds in photoshop or illustrator. Just create the image, lay down your colors and add a Gaussian blur. Have you tried this?
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
