Activity › Forums › Apple Final Cut Pro Legacy › Multiclips will not Media Manage
  • Multiclips will not Media Manage
    Posted by Simon Chan on July 21, 2005 at 1:23 am
    I can not get Multiclips to Media Manage properly. Media Manager does export out the clips with handles but it will not reconnect them back into a sequence. It reconnects the Multiclip which is collapsed. Anybody have this probelm and know a solution?
    P.S. Multiclips also get screwed up when I import an Automatic Duck OMF into After Effects. Any clip that was a Multiclip is totally off sych by many frames.
    Simon Chan replied 21 years, 2 months ago 2 Members · 2 Replies
  • Tom Wolsky
    July 21, 2005 at 1:32 am
    I ran some tests with MM on multiclips and didn’t find a problem. What MM function were you using? What’s the original material and its timecode?
  • Simon Chan
    July 21, 2005 at 2:21 am
    DVCPRO HD is the format. I am using copy, delete unused media, add 12 frame handles, duplicate items into new project. All the clips that are not Multiclip work fine. Only the Multiclips are malfunctioning. and its just to reconnect them. Media Manager is still making correct clips with handles of the Multiclips. Its just not reconnecting them. My only solution is to reconnect manually.
