  • Posted by Stefano Bianco on September 12, 2008 at 6:48 pm
    I’ve big headache with a multiclip issue: when I move all my project to an hard disk that I need to work at home, multiclips stop to work properly.
    I’ve notice that a green render (preview) or a dark green render (full) appears on top of problematic sequences. I am using dv pal square pixel codec, this actually works well in the production studio where I am working but not so well when I use it in the hard disk that I am trying to take back home.
    I appreaciate any suggestion on this issue, I’ve tried everything and the best suggestion so far it was that to use media manager to move all the project.
    TNX so much.
    Stefano
    Stefano Bianco replied 18 years ago 2 Members · 2 Replies
  • Herb Sevush
    September 12, 2008 at 7:10 pm
    Stefano
    What version of FC are you using?
    Versions prior to 6.0.3 were liable to corrupt multi-clips when media was moved from one system to another, someimtes even when moved to different drives on the same system.
    If your only problem is that you are getting green bars it might be that your home drives aren’t fast enough – multi-clips require a lot of drive speed.
    Herb Sevush
    Zebra Productions
  • Stefano Bianco
    September 14, 2008 at 11:11 pm
    I ‘m using now 6.0.3 but I don’t think that s the problem, since other operators used my mac station before and done successfully the job. I recompress the clips using compressor, some of my friends said that was the problem, since, they said, i should have used only media manager… my god it is such a trouble.
    well tnx for ur help and for any other.
    stefano
