Activity Forums Apple Final Cut Pro Legacy Multiclip Workflow and Audio
  • Multiclip Workflow and Audio
    Posted by John Thomas on February 8, 2007 at 10:37 pm
    I’m working on a 3 camera project and the problem is in the audio. 1 camera has a wireless mic and the other 2 cameras are used for general sound. I’ve come up with this workflow and was wondering if anyone had any better ideas.
    Multiclip Workflow
    1. Create in points of 3 cameras for multiclip in a sequence V1, V2, V3 and drag back to a bin in browser.
    2. Create multiclip Sequence from that bin
    3. Place the Multiclip Sequence in the timeline @ V4 above the 3 cameras in V1, V2, V3 without audio
    4. Select the shots fm Multiclip
    5. Trim edit the shots and delete dead space
    6. Send the audio to Multitrack for Mixing
    7. Finish up with Titles, Effects, Transitions etc.
    Any thoughts would be appreciated.
    John
    John Thomas replied 19 years, 7 months ago 3 Members · 5 Replies
  • Travis Ballstadt
    February 8, 2007 at 10:43 pm
    You’re on the right track. With only three tracks, though, you could save the trip to STP and mix your audio in FCP. I recently did a 6 camera multiclip with 24 tracks of audio completely in FCP.
    travis ballstadt
    http://www.thrillcateditorial.com
  • Dan Riley
    February 9, 2007 at 3:35 am
    I’ve done many multicam shows, FCP and AVID, and maybe I’m missing something
    but why are you going through all that V1, 2, 3 stuff? Make multiclips from
    timecode or in or out points. Then drag the multiclip you want to use to a sequence.
    You tell FCP to use whichever audio you want from which ever
    camera you want, if it’s cam 1, fine. Cut live or stop and pick. Done.
    If you want to add wild audio from those cameras, match frame and add it to A2 or A3 or
    whatever where needed.
    Why are you using 4 video tracks for a multicam edit. We don’t need to do that since FCP5.
    Dan
  • Travis Ballstadt
    February 9, 2007 at 3:46 am
    I think he’s laying the 3 master clips out on the timeline to sync them up, then creating the multiclip. He’s then leaving the audio in the timeline to mix between.
    travis ballstadt
  • Dan Riley
    February 9, 2007 at 3:48 am
    I guess I was missing something 🙂
    Wouldn’t be the first time.
    Dan
  • John Thomas
    February 9, 2007 at 11:25 am
    Yes, I have some parts of audio that are bad on the two cameras that have the general audio and the one camera that has the Lav. That way I can mix the audio when I’m through triming.
    John
