Activity › Forums › Apple Final Cut Pro Legacy › Multiclip sync Retarded
  • Multiclip sync Retarded
    Posted by Donkey Dave on June 16, 2006 at 8:06 pm
    I have a number of tapes that were filmed on 2 separate camcorders. The timecodes don’t even come close to matching up so I can’t sync them that way and the in / out points don’t match up either. The only way I have found to sync them in the multiclip viewer is to ctrl-shift and drag frame by frame. I don’t have an extra 15 hours to go through frame by frame and sync my footage. Anybody have any ideas. Is the multiclip sync function retarded or is it just me.
    Tim Phillips replied 20 years, 3 months ago 5 Members · 4 Replies
  • John Pale
    June 16, 2006 at 9:14 pm
    [Donkey Dave] “Is the multiclip sync function retarded or is it just me.”
    I don’t know anything about your mental faculties, but the multiclip sync function is not retarded. If you have never used it before, or the similar function on Avid, then you need to read the manual.
    If your source timecodes don’t match (which is quite often the case, unless you are lucky), you can set a common in point among all the angles using a visual or audio cue.
    Volume 2 (Editing) Page 247 in the Final Cut Help would be a good place to start.
  • Frank Nolan
    June 17, 2006 at 1:18 am
    Well Dave,
    We all know Donkey’s are a little slow, but retarded?
    [Donkey Dave] “the in / out points don’t match up either”
    What in/out points are you talking about? What you need to do is set in points that do match up, then make your multiclip using the in points.
  • Tony
    June 17, 2006 at 3:24 am
    The only thing retarded is the guillty party who allowed or created the mess in the first place during the shoot.
    Was this a case of a producer not being willing to pay for an engineer or gear necessary to provide jam sync timecode to all the camcorders?
    Well suck it all up and bill them double for all your extra time.
    The phrase “We’ll fix it in post” does not apply here ….. at least not cheaply.
    Tony Salgado
  • Tim Phillips
    June 17, 2006 at 1:07 pm
    After 12 years on an Avid I switched to Final Cut about three months ago. I had a need for multiclip for the first time just three days ago in a situation just like yours with two cameras and different timecodes. I did some quick reading, found a great tutorial on the Ken Stone website and was multiclipping along in no time. I couldn’t believe how easy and incredibly handy it was.
    It was in no way difficult. Or retarded. And by the way, if you know anyone with children that have mental challenges, you’ll realize that using that word in your everyday life to explain things like edit functions makes you look very bad.
    Tim
