Activity Forums Apple Final Cut Pro Legacy Multiclip Sync Issues
  • Multiclip Sync Issues
    Posted by Nick Derrico on September 11, 2009 at 2:45 pm
    I am having this odd problem when working with multiclips, it all started when I upgraded to 7.0.
    After changing the sync menu to Open and pressing playing, I can begin to select different angles within the multiclip as normal. However, if I adjust an angle in a multiclip while NOT playing back, the next time I hit play, the viewer no longer advances with the timeline. However, if I check the sync option, it still says Open. I have to unselect and reselect open in order to get it to work correctly again. This gets really annoying when I am a bunch of multiclips and need to adjust initial angle on everyone.
    If anyone has ideas, let me know. If not, does anybody know the best way to submit potential bugs to Apple so that can (hopefully) fix them? Everything worked fine in 6.0, so I find it hard to believe that the problem is just on my end. Thanks!
    Nick Derrico replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
