Activity Forums Apple Final Cut Pro Legacy Multiclip Shortcuts Not Working
  • Multiclip Shortcuts Not Working
    Posted by Brandon Smith on July 5, 2010 at 6:30 pm
    I’m currently switching from doing my multicam editing on Premiere to FCP. So, I know there is probably a very simple solution to this, but I can’t figure it out for the life of me.
    I have my multiclip sequence and clips all set up. I have open sync turned on, and multiclip playback enabled. I have selected tools>keyboard layout>multiclip editing about ten times now. Still, I can not get any of the multiclip shortcuts to work. Everytime I try to change angles during clip playback, the clip stops and either a checkmark, or an exclamation mark appears in the canvas window, and no edits have been made. If I use the button bars to switch back and forth between cameras, it works just fine; its only when using the keyboard that I am having a problem. Anyone have any help they could offer? It would be greatly appreciated.
    For what its worth, while I like FCP better overall, multicam edits are much easier to set up in Premiere.
    Brandon Smith replied 16 years, 2 months ago 3 Members · 9 Replies
  • 9 Replies
  • Patrice Freymond
    July 5, 2010 at 7:49 pm
    could it be that you keyboard is setup in another language?
    The checkmark or exlamation point you get (in a warning triangle?) are your luma excess display which normaly gets activated by the ctrl-z shortcut…
    Hope this helps,
    Pat
  • Brandon Smith
    July 5, 2010 at 9:19 pm
    Under tools.keyboard layout, it says default layout-U.S. So I don’t think that is the issue. Other ideas?
  • Tom Wolsky
    July 6, 2010 at 12:36 am
    Are you playing back the timeline or the viewer?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Brandon Smith
    July 6, 2010 at 4:55 am
    I seem to get the same result either way. I’ve noticed if I hit apple+2, which should be cut to video angle 2 in the multiclip keyboard, it hides the canvas. That is the shortcut for hiding the canvas on the default keyboard layout; so it seems like maybe it isn’t changing the keyboard layout to multiclip, even when I select it.
  • Patrice Freymond
    July 6, 2010 at 5:34 am
    Hi again,
    what I meant by keyboard language was at the OS level, not in FCP…
    also, are you on a laptop?
    could it be you have the num lock activated somehow?
    Pat
  • Tom Wolsky
    July 6, 2010 at 6:28 am
    You’re pressing the wrong number 2. You have to press Cmd-2 in the keypad, not the keys across the top of the keyboard.
    All the best,
    Tom
  • Brandon Smith
    July 8, 2010 at 8:24 pm
    I’m not on a laptop, I’m on an IMac. There is only one set of keys :/ Also, I checked the language settings in system preferences and it is set on english. Is that what you were referring to?
  • Tom Wolsky
    July 9, 2010 at 12:22 am
    If you have the short keyboard it won’t work. If there’s only one set of number keys, no extended keyboard with a separate keypad then the multiclip shortcuts won’t work.
    All the best,
    Tom
  • Brandon Smith
    July 9, 2010 at 4:34 am
    That would be the problem. Thanks very much. I think I’ll try reassigning the shortcuts to work with the regular number keys.
