Multiclip – Resynchronising 2 angles
Hi ,
I am a newbie to FCP and working on a multicam edit.. quiet strait forward project for most i would imagine.
It is a theatre show shot on 2 cameras..
I have been editing real time multicam and it has worked a treat so far – half way into a 90 min min edit i have noticed that it had got out of sync due to droped frames or the sd card glitch maybe …
i know how to nudge the frames on multicam edits .. but what i can’t get my head around is as follows :
If i nudge the frames to resync to the point where the edit has drifted out.. will the previous 45 mins of edits be affected as well.. upto to this drifting issue i have checked and it is all good and in sync.. as i made the multiclip using In Points …
i can actually see where the drop frames are on one of the shots.. the images just jumps a few frames .. i have tried reimporting it and also looked at the original footage and it is on the original recording as well.. Avchd file that i have log and transfered.What i do not want to do is start messing with nudging the the multi clip to find all my fine work upto thgis point is worthless.. i have a gut feeling that it does not affect the previous edit points and just changes the from the last point in the viewer.. i have checked the manual and attached a screen grab – though the manual is vague as to what the implications are for the entire previous edit upto nudging frames to reysync the 2 angles.
Sorry this question is at tad long winded – need to know i feel as if it is a problem of dropped frames or card then i am pretty sure it will happen again during the remainder of the 45 mins left… too much stress to think abour!!
i just hope someone understands what my issue is and i need an experinced FCP guru to advise!!
Thanks in advance to one and all for reading this ,
GH
