Activity Forums Apple Final Cut Pro Legacy Multiclip resync error
  • Multiclip resync error
    Posted by Mathias Hekton on June 4, 2005 at 12:08 pm
    Having major problems with resyncing an angle in a Multiclip. I’m following the instructions in the manual and when I hold down the shift & ctrl keys I get the little symbol that show how many frames I moved, let go of the mouse and NOTHING happens. The clip does not move a singel frame. Did I miss something or is it a bug in FCP 5? If anyone has a clue please let me know.
    Except for this little problem the multiclip thing is awsome.
    /mathias
    Steve Finch replied 21 years, 3 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    June 5, 2005 at 3:33 pm
    I don’t see the problem here… yikes. Try trashing your preference file, but I sort of fear a reinstall is in your future…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mathias Hekton
    June 5, 2005 at 6:06 pm
    I’ll try tossing the prefrences. But I think maybe you have seen my future, reinstalling the app…………
    Thanks for taking the time to test the problem. Now I at least know that it is not a software bug.
    /mathias
  • Steve Finch
    June 14, 2005 at 1:25 pm
    We are using multiclip with 6 angles brought in from HD CAM at DV resolution for off-line. It works awsome! Even on my new G4 laptop no hitches at all except multicam trim mode. Same problem. Shift-Contl and the hand appears but no results after you have shifted the frames. I’ve loaded Final Cut Suite on to three diffferent different boxes, one a new 1.67 GHz G4 lap top out of the box brand new and two dual G5s, and we still have the exact same issues on all 3.
