Activity Forums Apple Final Cut Pro Legacy multiclip render>loose multiclip in viewer?
  • multiclip render>loose multiclip in viewer?
    Posted by Redman on June 5, 2006 at 6:22 am
    i rendered my multiclip. i have now lost the multiple views in the viewer. when i pause the timeline, i get it back. but the viewer shows the actual edit when i play the timeline. is there a way to get the multiple clips back in the viewer when playing? or when you render do you lose the capibility? thx in advance
    Jayseaare replied 20 years, 3 months ago 2 Members · 1 Reply
  • Jayseaare
    June 13, 2006 at 5:29 pm
    Has anyone answered this question? I am having the exact same problem.
    What I have done as a quick fix is to only render the “Needs Rendering” and “Preview” (the red and neon green render colors, respectively) of the sequence manually (Render Only, under the Sequence menu), turn off the auto render in User Preferences (bottom right in the general tab), so it doesn’t render on it’s own and cancel out the running multiclip in the viewer. The other colors of “needs rendering” types look fine during play back.
    When I am pretty much done with my edit, then I render the whole thing.
    I would be nice to figure out how to actually solve this problem, if someone out there knows.
    Good luck.
