Activity Forums Apple Final Cut Pro Legacy Multiclip render issues
  • Multiclip render issues
    Posted by Matt Wilson on January 16, 2009 at 5:18 pm
    Hello
    I am working in an HD timeline 1080 29.97, with a three camera multiclip. I have to play it back with unlimited rt and then render it out when I am done with the cut. It appears that the first camera in the multiclip doesn’t need to be rendered, however during playback it is pixelated, and It wont render like the rest of the cameras. I have to stick a broadcast safe filter on it and then render it out for it to work. Now that does the trick, but I am wondering if one of my settings is off or if there is something in the sequence settings that I am missing.
    Matt
    Jerry Hofmann replied 17 years, 8 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    January 17, 2009 at 3:03 pm
    Did all three cameras match? All were the same codec? This was HDV or? HD 1080 comes in a bunch of flavors actually, could be HDV, or XDCAMHD or another half dozen flavors, and in order to use multiclips without problems, is to make all the video be using the same codec.
    If you had to render in the end and didn’t have any filters involved, then the sequence settings didn’t match the clip’s properties. You should only have to render if you add a filter.
    As a side note: The broadcast safe filter isn’t the best way to make it safe either. Color correction does a much better job of preserving the images and making them legal. Broadcast safe just clamps what’s illegal and loses the detail in those areas when it is applied. (which in some cases doesn’t matter, but usually it does). Japanese cameras over expose everything if you use automatic exposure settings too. It’s much better to use a waveform monitor or light meter to expose correctly in the first place – not needing to make them safe per se, but using color correction to bring out the richness that video cameras just can’t seem to maintain. Makes a world of difference IMHO. But I’m digressing a bit.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
