Activity Forums Apple Final Cut Pro Legacy multiclip Questions Answered – A new Trick!
  • multiclip Questions Answered – A new Trick!
    Posted by Bob Flood on October 19, 2010 at 7:30 pm
    Gentlemen
    Based on response from my previous post (multiclip questions) I have found a solution to the issue I was having with 2 disimilar cameras not matching in a multicam edit.
    1. Went into Color with the lesser of the 2 original camera clips (the whole clips as captured) in this case HDV footage from a Z1U, which i wanted to match to a 5D. Based on info from these very forums, i was able to adjust the contrast ratios of the lesser shot so it matched the 5D clip(s)
    2. “rendered” the Color result, which created a QT file named 1_g1.mov
    3. Using QT Player Pro, I was able to Add this video file to the original Pre Color file, which had 8 channels of audio. Then went into Movie Properties in the QT Player, and deleted the original Video track, as well the second timecode track. Now I have a file with the same attributes as the original, but with a proper color grading.
    4 Opened the FCP project and Viola.. the new footage shows up fine!
    WOW! so much easier this way
    Caveats: I made a copy of the original HDV Capture movie, and called it **Original.mov so i could go back to it if necessary. I also made sure all the clips are excatly the same length and format.
    Thanx again. Now i am going to correct the rest of these lesser shots!
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Michael Sacci replied 15 years, 11 months ago 2 Members · 1 Reply
  • Michael Sacci
    October 19, 2010 at 8:52 pm
    QT Pro is a very useful program, have done the copy and paste thing many times.
