Multiclip question
I’m cutting a four camera music show shot with four individual Digibeta cameras. Three were in fixed positions with locked TOD time code. The fourth was a hand held running TOD code, initially locked to the master code. This free running timecode ended being about a second and 26 frames off from the master clock. No big deal. I’ll just use the in points for each clip as the reference in the multiclip and all will be well. This works fine for most of the songs. But old habits die hard and my hand held camera guy accidentlly paused the tape at a few places resulting in a break in the timecode at those points. While capturing the clip FCP broke these clips into multiple clips with a resulting gap in the timecode.
Here’s the problem. How can I sync up these various clips in a multiclip? I can’t use in points for a reference any longer and I can’t use timecode due to the 1 second and 26 frame offset on the 4th camera. Is there any to add an offset to the 4th camera clips after they have been captured or add the offset within the multiclip itself? I could break the song into several multiclip sequences at the points where the camera was paused…but I’d rather not if possible.
Some multiclips would need to have around 8 tracks synced together. Suggestions?
Thanks in advance,
Tom(Man, I’ve had a lot of posts this week…whew!)
