Activity Forums Apple Final Cut Pro Legacy Multiclip proxy file creation – smallest possible
  • Multiclip proxy file creation – smallest possible
    Posted by Jeff Beardall on July 5, 2011 at 12:45 am
    I’m editing a music video with about a dozen angles. The footage was shot on a Nikon D7000. I would like to be able to play back as many clips as possible in a multiclip sequence. I have a very modest system (Macbook Pro 2.66 Core 2 Duo and a small RAID that does about 125 MB/s). I have transcoded all the footage to Prores LT to use for final render, but I am having a good deal of difficulty finding a proxy file size and setting that will allow RT or even 1/4 RT playback on the timeline. I’m assuming if I create proxy files that are small (640×360, square pixels) and of low enough bitrate, that I should be able to play back a decent number of proxy clips in a multiclip sequence. Prores Proxy does not seem to play back at all when reduced to 360p…does anyone have a practical suggestion for creating small enough proxy files to allow this? TIA, Jeff
    Jeff Beardall replied 15 years, 2 months ago 1 Member · 1 Reply
  • Jeff Beardall
    July 5, 2011 at 11:37 am
    Never mind…went with HDV 720p as a proxy and that seems to work fine for at least 9 clips.
