Activity Forums Apple Final Cut Pro Legacy Multiclip problems
  • Multiclip problems
    Posted by Dylan Etherington on March 10, 2010 at 11:35 pm
    Hi everyone.
    I’m editing a sequence together using the multiclip facility at the moment. I’m only using 3 video sources so it’s not a major operation and everything was going fine until I turned my computer back on this morning.
    Initially when I press play in the sequence it stopped after about a second and said that frames were being dropped during playback. This happened no matter where the cursor was in the timeline. Then after leaving it for a while it would play back continuously however at a reduce frame rate. It looked about only 8 fps so it was very jerky.
    I’ve tried loading everything into a new sequence and that hasn’t worked. I’ve tried transferring it all to another hardrive and that didn’t work. I even opened a new project so set up another edit and I still had the same issue. Could it be to do with my computers memory? I’m editing on a 2008 MBP in FCP 6.0.3 and have 2 gigs of RAM. I just can’t understand why it was fine and now it isn’t.
    Thanks very much.
    Dylan.
    Mark Arcusa replied 16 years, 6 months ago 3 Members · 6 Replies
  • Matt Geier
    March 11, 2010 at 1:08 am
    Hi Dylan,
    I’m not an expert with Multi Clip (yet) but I’m just going to ask some basic questions to clear up any of the initial questions that come to mind;
    Have you been doing this / done this before with this rig you have?
    What kind of video formats are you using?
    Are you editing local or over network?
    Let us all know!
    Matt
  • Dylan Etherington
    March 11, 2010 at 9:07 am
    Hi Matt, thanks for the response.
    I’ve not edited a multiclip before. This is the first time it’s been done on this machine. The format is HDV 1080i, all shot on Z1’s. I’m not sure what you mean by editing local or network but I’ll take a guess. The laptop I’m using isn’t connected into a network of other computers or linked up to a server (if you meant something else then please excuse my ignorance).
    Dylan
  • Dylan Etherington
    March 11, 2010 at 11:00 am
    Problem solved now!
  • Matt Geier
    March 11, 2010 at 4:40 pm
    Dylan,
    What I do know is that doing Multi-Clip, is a lot more strict on hardware then say, no Multi-Clip editing.
    With regard to editing “local” or across the “network” — these are two common methods for editors to have “local attached disks at your Mac” or “network attached disk that go over Ethernet or Fibre Channel or some other wires”
    Hopefully that helps. Don’t feel ignorant about networking, you’re an editor. 🙂
    BTW — How did you resolve your problem?
  • Dylan Etherington
    March 11, 2010 at 4:55 pm
    Thanks Matt!
    I opened another project that I knew was fine and it had the same problem too so it obviously had nothing to do with the multiclip project. Shut everything down and left it for ten minutes and when I booted it back up again it was working fine. I guess whatever went was was reset when my computer was turned off.
    Dylan.
  • Mark Arcusa
    March 18, 2010 at 2:40 am
    Sounds stupid, but are you in the right screen resolution? If you’re in anything but 1024 x 768 (or whatever that warning says) it is unpredictable. I’ve had the jitter thing before, and for some reason I tried changing it and it was fine.
