Activity › Forums › Apple Final Cut Pro Legacy › Multiclip problem
  • Multiclip problem
    Posted by Denis Klimenko on May 31, 2009 at 10:54 am
    Hello everybody! I have the problem with the camera angle recognition in Multiclip.
    All clips from the same camera (P2 Panasonic 500 ) recognized like different cam angles by Multiclip.
    I tried to force FC by entering cam angle thru the properties in browser, changing file names according to file names convention (like in help docs) – all the time I got Multiclip with 126
    original cameras. Does it common software bug or something broken in my installation?
    Does anybody have the same problems? Any solutions? Thanks.
    http://www.postproduction.narod.ru
    Denis Klimenko replied 17 years, 3 months ago 4 Members · 6 Replies
  • Zane Barker
    May 31, 2009 at 2:24 pm
    How are you having the multi clip sync up the clips is it my, in point time code etc?
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Denis Klimenko
    May 31, 2009 at 5:49 pm
    It doesn’t matter – I don’t have problems with sync. The trouble is in camera angles recognition.
    Why I can’t force FC to make one cam angle from two clips with different timecode?
  • Arnie Schlissel
    June 1, 2009 at 3:05 am
    [Denis Klimenko] “Why I can’t force FC to make one cam angle from two clips with different timecode?”
    Because it doesn’t work that way. You need to use a multiclip sequence, and then the timecode from the 2 clips should be related. This is explained in the FCP manual. Look up multiclip sequences and read that section completely.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Denis Klimenko
    June 1, 2009 at 12:52 pm
    Thanks, was confused exactly by this frase
    User Manual Vol2 р 246
    “When you create a multiclip, Final Cut Pro sorts the clips you selected by the values in
    their Angle properties. If a clip’s Angle property is empty, Final Cut Pro looks at the clip
    name, reel name, and finally the media filename to derive angle information. Final Cut Pro
    assumes the first number in the reel name or filename is an angle number. ”
  • Herb Sevush
    June 2, 2009 at 4:39 pm
    Dennis –
    Final cut only allows 1 clip per camera angle for any given multi-clip. In other words you cannot have multiple shots from camera A in the same multi-clip. The only way to get around that is to create a timeline for each camera angle, with all of your clips laid out in sync with timecode and then export separate movies for each angle and then use those clips to form your multi-clip. It’s a bit of a work around but I’ve worked this way and if you have lots of start and go clips, or have to import P2 footage from FireStore drives, it beats working with dozens of separate multi-clips.
    Herb Sevush
    Zebra Productions
  • Denis Klimenko
    June 4, 2009 at 6:45 pm
    Thank’s Herb! Eventually I got clear and direct answer to my qestion.
    I already solved this problem exactly like You advice in your post.
