Activity › Forums › Apple Final Cut Pro Legacy › Multiclip not syncing properly
  • Multiclip not syncing properly
    Posted by Adam Welby on May 21, 2012 at 3:17 pm
    Hello All
    I’m trying to put two XDCAM HD clips and a MONO.wav audio file into a multiclip. I’m doing so by manually syncing them in an independent sequence and trimming the in-points to match, then ordering the multiclip file to sync them by in-points. The results have been tragic to say the least. Sometimes two of the pieces of media properly align, but it’s random. Sometimes one angle with the audio, the other angle with the audio, or the two angles sync and the audio is in its own world.
    Does anyone have any idea why it would be doing this? The only thing I’m doing different than anything before is the audio files I’m using are subclips of a long audio file. Any help is greatly appreciated.
    Adam Welby replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
