Activity › Forums › Apple Final Cut Pro Legacy › Multiclip needs rendering when containing more than 2 clips.
  • Multiclip needs rendering when containing more than 2 clips.
    Posted by Martijn Calkhoven on November 11, 2009 at 12:22 pm
    I’m working on a multi edit, using 3 different camera’s. The footage was captured by someone else, I dropped them in the capture scratch location (\capture scratch\\video.mov) and imported in the project. When I drag one clip in a sequence, the bars are grey and I don’t need te render. However, if I make a multiclip of 3 or more clips, the bar turns red and I need to render. Not knowing how to solve this, I rendered the clip. I had a feeling this wouldn’t solve it, and I was right. It just rendered the active clip, the other 2 were still not usable. I compared the sequence to the one my colleague made. They’re identical, yet he doesn’t need rendering. What am I doing wrong?
    Martijn Calkhoven.
    Martijn Calkhoven replied 16 years, 10 months ago 2 Members · 2 Replies
  • Mike Kahn
    November 11, 2009 at 5:18 pm
    Are all three the same compression and frame rate? What are the specs of the media? What version of FCP are you using?
  • Martijn Calkhoven
    November 11, 2009 at 7:24 pm
    I forgot to mention that only the video bar is red, the audio doesn’t need rendering. The footage is compressed to “HDV – 1080i50” at 25 fps.
    I don’t know what other specs you need, but here are some:
    Data Rate: 3.2 MB/sec
    Audio Rate: 48.0 KHz
    Audio Format: 16-bit Integer
    No alpha
    Field Dominance: Upper (Odd)
    I am using FCP 5.1. My colleague is using FCP 7 and uses the same settings I do.
