Activity Forums Apple Final Cut Pro Legacy Multiclip Master Clip not Present Problem!!!
  • Multiclip Master Clip not Present Problem!!!
    Posted by Trevor Ambrose on July 7, 2010 at 8:48 pm
    Hey Guys,
    I’m in a real bind. I’ve just started editing a series and myself and the 1st assistant cannot figure out a major multiclip problem.
    When using the “shift/F” function (find clip in browser) we keep getting this prompt: “THE MASTERCLIP IS NOT PRESENT. WOULD YOU LIKE TO ADD MASTERCLIP TO THE BROWSER”.
    In other words we can FIND FRAME but we can’t FIND IN BIN.
    This is an intermittent problem. Sometime we can find in browser, sometimes not.
    Also, I doubt this is relevant but it’s a Red Camera show.
    Any insights?
    Trevor Ambrose
    Nick Meyers replied 16 years, 2 months ago 2 Members · 1 Reply
  • Nick Meyers
    July 8, 2010 at 3:22 am
    this will definitely happen if you are cutting from rushes that are in one project
    into a sequence that’s in another project.
    FCP cant maintain the Master Affiliate relationship between projects,
    as each project is a self-contained database.
    also, do you want to find the master clip for one camera?
    that’s what Shift F will do.
    if you want to reveal the Master Multiclip, then that is possible, but you have to create your own shortcut for that.
    (you can co-opt Shift F if you want)
    Tools > Keyboard Layout > Customize (or Option H)
    this is probably straying fro your topic, but this is a copy/paste from a recent post i made on another list:
    it can also happen within the one project that the Master Affiliate
    relationship just breaks.
    it can happen with a few clips, or it can happen with all the clips.
    why it happens i don’t know, so i don’t know how to prevent it from
    happening.
    it did happen on the film i’m cutting now, and i was able to fix it.
    i went though my auto-saved version till i found the last one where
    the M/A relationship was intact,
    meaning i could Shift-F from a clip in a sequence to the browser.
    i did a save as,
    then deleted all the edit sequences,
    and copy/pasted my current edit sequences back into it.
    miraculously, that worked.
    (I may have copy/pasted then deleted, i suspect it would be the same)
    this was ok or me as we were done shooting, so no new clips had come
    into the project,
    but the cuts had been changing.
    hope that helps,
    nick
