Activity Forums Apple Final Cut Pro Legacy Multiclip from a sequence
  • Multiclip from a sequence
    Posted by Ilya Osovets on March 12, 2012 at 6:24 pm
    Hey Everyone!,
    I’m having a little issue with creating a multiclip. I used Pluraleyes to sync up a 3 camera shoot.
    Everything looks good on the timeline. However when I tell Pluraleyes to create a multiclip it creates one but there are only 4 shots and everything is black.
    Not sure whats going on.
    Is there a way to create a multiclip from a sequence in FCP?
    Ilya Osovets replied 14 years, 5 months ago 1 Member · 2 Replies
  • Ilya Osovets
    March 12, 2012 at 11:33 pm
    I cant seem to get a multiclip from this sequences.
    Everything I keep trying just leads to no where. Pluraleyes does create a clip but it has aline though it like its offline. And when double click in it i get a General error and it says out of memory.
    I read on here that someone make each track a independent clip in the sequence. However ever time I try to use the independent clip option nothing happens.
    Any thoughts?
  • Ilya Osovets
    March 13, 2012 at 1:13 am
    The only way I can figure out a solution is to export each track as a QuickTime Reference file and then bring them back in and do a multi clip.
    That kinda works but now the issue Im having on halfway though those QuickTime files the audio becomes crazy distorted and loud. Its fine in the timeline and in the original files but on the QuickTime its just crazy…
    any ideas?
