Activity Forums Apple Final Cut Pro Legacy Multiclip export problem
  • Multiclip export problem
    Posted by Tom Mooney on June 4, 2005 at 7:02 pm
    We have a 7 hr multiclip program on a timeline and now I need to export it in pieces to run a set of DVD’s. When I export, FCP will not give me a reference file to load into DVD studio. It recompresses the media and turns it into a self contained movie taking up huge amounts of drive space . I do not want to compress this footage again, what am I missing?
    Thanks in advance
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 5, 2005 at 3:32 pm
    Before you export the file, try the”collapse multiclips” command found by right clicking on a clip after you select the multiclips, and don’t forget to turn off the “make self contained option”… you can toggle this off and on the same way all you want too.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
