Activity Forums Apple Final Cut Pro Legacy Multiclip Editing with DVCPRO HD
  • Multiclip Editing with DVCPRO HD
    Posted by Ingmar Lara on May 27, 2008 at 5:29 pm
    I am editing with 3 camera angles, all shot on DVCPRO HD, and have created Mulitclips with them. The Multiclips play back fine, but when I create an edit in the sequence, I have to re-render the clip. This has never been an issue with DV. Is it possible to Multiclip edit in REALTIME with DVCPRO HD? I am using FCP 6.0.2. On a Dual-Core Intel, running on MAC OS X 10.5.1. Using 4GB of RAM. Let me know if anyone has any input. Much appreciated.
    Francis Battaglia replied 18 years, 2 months ago 6 Members · 5 Replies
  • Chris Borjis
    May 27, 2008 at 8:13 pm
    reload your sequence settings for whichever spec of dvcpro-hd your using.
  • Shane Ross
    May 27, 2008 at 10:33 pm
    A faster RAID array will help greatly here. You cannot get 3 streams of DVCPRO HD in a multiclip via firewire. Two drive RAID 0 or better.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Nate Adams
    May 27, 2008 at 11:52 pm
    Agreed Shane. There isn’t enough throughput on a firewire setup to handle the bandwidth required by 3 streams of DVCProHD. Add to that the fact there’s most likely motion effects applied (since it’s three streams we’re talking about), and it’s a lot for the computer to do. The demands only increase as you move up to 1080i.
  • John Pale
    May 27, 2008 at 11:56 pm
    Try turning off your realtime scopes.
    (just control click on the scopes for the option).
  • Francis Battaglia
    June 10, 2008 at 1:14 am
    anyone experiencing crashes editing DVCPRO HD?
    multiclip sequences or not, even deleting clips causes a crash…
    running FCP 6.0.3 with 720p60 codec – dual quad core Mac Pro 3.0 with three striped internal drives and 13 GB of RAM…any tips appreciated.
