Activity › Forums › Apple Final Cut Pro Legacy › Multi_Clip Editing Problem
  • Multi_Clip Editing Problem
    Posted by Keith Hill on July 29, 2005 at 2:13 am
    I am trying to perform a multi-angle edit using the new Multi_clip editing feature. Following the tutorial setup I am at the point where a Multi-clip has been created and loaded into the Timeline. Once the M-clip is in the Timeline I double clicked to load it back into the viewer. Next, I am supposed to ‘click’ the Playhead Sync Open button from the Viewer window, then click above the M-clip in the Timeline to de-select it.
    From this point I am supposed to be able to hit my Spacebar and see the camera angles playback in the viewer while I hit Shift+Camera Angle # (on the numeric keypad).
    The problem occurs when I hit play and the camera angles go from 4-up to 1-up view. When I hit pause it goes back to 4-Up. I’m supposed to be able to view the angles playing back in realtime in the Viewer while I rehearse switching angles. This isn’t happening and I’m frustrated. Any ideas?
    Keith Hill
    https://www.LightedPath.biz
    Dallas, TX
    Final Cut Pro 5.0.2, Combustion (MAC-v3.0.4), DVD StudioPro 4 (v 3.0.2); MAC G5 (v10.4.2-Tiger) 2Ghz, 1.5 RAM
    Keith Hill replied 21 years, 2 months ago 2 Members · 3 Replies
  • Les Kaye
    July 29, 2005 at 6:24 am
    Did you choose multiclip playback from the RT tab on the timeline?
  • Keith Hill
    July 29, 2005 at 8:32 am
    Yes. All of the RT settings are in place.
    Keith Hill
    Dallas, TX
  • Keith Hill
    July 29, 2005 at 10:28 pm
    For those watching this.
    Here was the problem. I shot this concert in 24pAdv (23.98) using my DVX100A. I captured all of the show in 24p with Pulldown in FCP5. The mistake came when I didn’t apparently have my Timeline setup in 23.98. By it being 29.97 I was able to go through all of the motions but when it came to actually performing Angle Switching in a Multi-Clip this was a no-go.
    Something told me to create a new project and Timeline and this is when I discovered that in the Sequence Item Properties that the Timeline was 29.97. I knew something was going on when I a had to constantly render the timeline when I made any ‘false’ moves. I have actually performed a cut yet but I have been able to switch angles and rehearse the cut.
    So, I guess the moral of the story is that your clips, sequence timeline ‘all’ have to match up. There can be no mixed-matching in a multi-clip.
    Keith Hill
    Dallas, TX
