Activity Forums Apple Final Cut Pro Legacy Multiclip editing
  • Multiclip editing
    Posted by Phil Wolf on May 12, 2009 at 3:17 am
    I set my my clips for multiclip editing. I have 3 clips in the Viewer, sync is set to open, i’ve set my I and O points and edited my clip into the timeline. My sproket holes are showing indicating i’m linked to my clips in the viewer. The problem is when I go to play my clips simultaneously the only clip that plays is the clip highlighted in blue-my chosen video clip. How do I get it to play all three clips at the same so that I may choose from each clip as they play and make my selections?
    Phil Wolf replied 17 years, 4 months ago 3 Members · 3 Replies
  • Michael Sacci
    May 12, 2009 at 5:51 am
    Has the footage been rendered, if it has it will playback only the selected clip.
  • Don Greening
    May 12, 2009 at 2:44 pm
    Also make sure that the multiclip is set to “Un-collapsed”.
    – Don
  • Phil Wolf
    May 13, 2009 at 5:53 pm
    Thanks for your help, though I found that in the system settings menu under the playback control tab, “Multiclip playback” was not checked. I checked it and it now runs smoothly.
