Activity › Forums › Apple Final Cut Pro Legacy › Multiclip editing
  • Multiclip editing
    Posted by Stevec on November 7, 2005 at 10:30 pm
    I’m trying to do a multiclip switch and as I run thru the clip and hit 1, 2or 3 to choose my angle it places a small blue tick on the top of the time line, but when I press the space bar to stop or get to the end of a clip the blue ticks disaper and the multiclip did
    Herb Sevush replied 20 years, 10 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    November 8, 2005 at 2:00 am
    Try changing the keyboard layout to multicam editing… then the number keys on the keypad will work…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Stevec
    November 8, 2005 at 1:33 pm
    The keyboard is set to
  • Les Kaye
    November 8, 2005 at 2:02 pm
    Can you cut to an angle when you’re simply parked at a point? If you can (or I guess even if you can’t), perhaps (and I hate to say this…) trashing your prefs might fix the problem. I generally only do multicam editing on FCP, and haven’t had this problem.
    About the other issues however…
  • Stevec
    November 8, 2005 at 2:57 pm
    I can cut and switch to an angle when parked at a point I tried trahing the preferences and still the same thing happens.
    Maybe I am misunderstanding the difference between a switched version and a cut version.
    As I understand it a switched version will change the angles, but not actually cut the time line while a cut version will actuall place visual cuts in the time line that you can navigate to.
    Steve
  • Herb Sevush
    November 8, 2005 at 3:41 pm
    Steve –
    You’ve got it wrong. The “switched” version is meant to be a preview. However if you are parked on the timeline and use the “switch” keys it will chnage the angle of the clip you are parked on. If you want to live cut the show you have to use the “cut” keys.
    I don’t quite understand why you would want to switch the show and keep the markers but not actually implement the cuts? It’s so easy to alter the cut points and still see all the original angles after you cut up the timeline it seems like a waste of effort.
    Herb Sevush
    Zebra Productions
