Activity Forums Apple Final Cut Pro Multiclip default active audio and video angle in event?
  • Multiclip default active audio and video angle in event?
    Posted by Bret Williams on October 11, 2012 at 4:48 pm
    Maybe I’m forgetting something. Seems like I’ve done this before but can’t seem to make it work today. I have a number of multi clips in the event. Within the angle editor, I have the monitoring angle set to Cam B, and the audio set to the audio only track. But how do I make those the default for scrubbing and viewing them in the event? It simply defaults to Cam A and it’s audio.
    If you put the event into list view, you can highlight the clip and in the inspector into you can see the default cam angle and default audio angle. But when you try to click in the inspector it instantly switches to “nothing to inspect” because it’s switching to the project view where I have nothing highlighted.
    Bret Williams replied 13 years, 11 months ago 1 Member · 1 Reply
  • Bret Williams
    October 13, 2012 at 1:03 am
    I figured this one out. Its a bug. When you’ve got the evens on you second monitor, and you highlight several clips and try to make a universal change in the inspector on the other screen, it will kick you out of the events and into your open sequence.
    Put the events back on the main monitor and all works as expected.
