Activity Forums Apple Final Cut Pro Legacy Multiclip: Can I change the default option for “Synchronize using”?
  • Multiclip: Can I change the default option for “Synchronize using”?
    Posted by Dan Shott on May 20, 2009 at 8:20 pm
    Hey everyone,
    I’m doing a lot of multiclipping (by timecode) for a new show I’m working on. When I select the clips and choose Make Multiclip, the deafault for Synchronize Using comes up as In Points. Is there any way I can make that come up as Timecode instead?
    -Dan
    Herb Sevush replied 17 years, 3 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    May 20, 2009 at 8:26 pm
    Chnage the drop down to timecode.
  • Dan Shott
    May 20, 2009 at 8:28 pm
    Right, but the next multiclip I make it defaults back to In Point. I’m looking to change it as the default everytime I make a multiclip.
  • Herb Sevush
    May 20, 2009 at 10:40 pm
    Dan –
    You can’t change the multi-clip defaults; it’s always set to in-points. It’s a typical type of annoyance found in all NLEs that serve to remind you that they are designed by software engineers, not editors.
    Herb Sevush
    Zebra Productions
