Activity Forums Apple Final Cut Pro Legacy Multiclip audio slipping problem
  • Multiclip audio slipping problem
    Posted by Gregman on January 22, 2007 at 7:49 pm
    I created a multiclip with 6 different camera angles and all 6 video clips art lined up in the Multiclip perfectly but the audio is slipping in one of the
    clips. I am lining up the clips by their out points. Please help someone… Thanks, G
    Gregman replied 19 years, 8 months ago 2 Members · 2 Replies
  • Dan Riley
    January 22, 2007 at 9:25 pm
    Probably, and this is just a guess, that one camera was running
    in non drop frame mode and the others were running in drop frame,
    or the opposite. This will show up as the minutes roll on.
    Fo 30 seconds or a minute it will be no problem but after a while
    you will not see a match between the cameras.
    If this is the case, let me know and I’ll tell you how to fix this.
    Dan
  • Gregman
    January 23, 2007 at 3:44 pm
    Don’t this that’s the issue. It’s slipping too much. Example: If I turn the last half of a concert shoot into a muticlip, one of the six anlges starts off
    lined up witht the audio from the begining of the shoot. It’s almost a 30 minute slip. Very strange.
