Activity Forums Apple Final Cut Pro Multiclip audio question
  • Multiclip audio question
    Posted by Mark Coffey on July 7, 2012 at 10:32 pm
    I’m trying to get X to work for me but it ain’t easy.
    2 cameras, double system audio. I want to create a multiclip but I need to be able to work with the audio separately and so far I haven’t figured how to do that.
    Obviously I don’t want to create the multiclip with audio as an angle like one might do if this were a music video and the audio wasn’t going to be touched. So I tried creating syncronized clips; each camera synced with the double system audio. I can make a multiclip with the two syncronized clips but the Detach Audio selection is greyed out. I need to be able to edit the audio separately from the video.
    thoughts? work arounds?
    thanks
    mark
    MacPro Octo 2.8—10GB RAM
    10.7—FCS3 7.03 & FCPX—AJA IOHD
    Mark Coffey
    Tsunami Editorial
    Austin, Texas
    Al Nazareth replied 14 years, 1 month ago 4 Members · 3 Replies
  • Andrew Maslen
    July 8, 2012 at 3:25 pm
    Quite a few different ways I’ve seen on here to achieve this, but here’s my workflow.
    I still use Pluraleyes, as it seems to do a better job than FCPX’s built in Sync.
    Once Pluraleyes as done its stuff, it imports all assets into fcpx into a project giving me the ability to assign separate roles to the audio tracks I want to use. Then export separate roles for each audio track (just one step required). Re-import these tracks back into fcpx. Drag the multi-clip that pluraleyes created into a new project, drag the separate audio roles beneath. Multiclip with separate editable audio. I also set the multiclip audio to camera scratch to compare before dropping audio level before exporting.
    Andrew
  • David Eaks
    July 9, 2012 at 2:15 am
    You could use “synchronize clips” again to sync your multicam clip (consisting of the two synchronized clips) to the audio clip. Then go into the angle editor and turn off the audio, in the inspector pane, for each of the multicam angles. Then bring that into a new timeline, giving you a multicam clip with detached audio as a connected clip. You could make that into a compound clip so it’s easy to cut without losing sync and go into the compound to edit audio and switch angles, but I fear the project bloat and avoid compound clips for anything that needs lots of cuts.
  • Al Nazareth
    August 5, 2012 at 12:07 am
    Hi MArk,
    fellow Austinite here with similar problem.
    have you decided what to do?
    drop me a line!
    at
    nazaca at gmx dot com
    Alex
