Activity › Forums › Apple Final Cut Pro › multiclip audio; accessing separate tracks
Posted by Mark Coffey on February 25, 2013 at 7:04 pmI have dual system audio, a duel mono track and wish to be able to access the separate tracks in a multiclip. Break Apart Clip Items doesn’t work; not available after the multiclip has been made and not carried over when using it before making the multiclip. Thoughts anyone?
Mark Coffey replied 13 years, 6 months ago 3 Members · 5 Replies -
Michael Garber
February 25, 2013 at 7:16 pmDid you set the audio channel value of the original clip to dual mono before you synched it? Also, make sure that you have the correct audio angle selected in the multiclip viewer, otherwise you’ll be accessing the original audio.
Also, break apart doesn’t work on multiclips (unfortunately).
Michael Garber
5th Wall – a post production company
Blog: GARBERSHOP -
Mark Coffey
February 25, 2013 at 7:32 pmAre you saying that if the dual mono selection was made before the multiclip is made then the multiclip will allow access to both channels separately? I don’t think that’s correct but PLEASE, prove me wrong. Yes, I understand selecting the correct audio within the multiclip.
Michael Garber
February 25, 2013 at 8:13 pmIt was a suggestion. Have you tried it yet?
Michael Garber
Blog: GARBERSHOP -
T. Payton
February 26, 2013 at 3:53 pmIt is true that Multicam clips can’t be separated, but you should have all the control you need by selecting just the audio channels you need and “create” a clip that has just the elements you want that you would normally break apart.
We do quite a bit as or normal dual system recording and end up with 3 or more mic sources. In this example below, 7D Camera audio, a H4n Mic (stereo) and a Rode Video Mic (dual mono).
Here is the inspector settings for the clip in the timeline:
And here is the timeline with audio components expanded:
It is pretty amazing when you use it.
Does this help?
T. Payton
OneCreative, Albuquerque -
Mark Coffey
February 26, 2013 at 7:31 pmThank you, Michael, for your in depth reply. The solution is to include my audio only file(s) as an “angle” in the multiclip. Then in the angle editor select the audio “angle” and, in the info section of the inspector, change the configuration from stereo to dual mono. Append the multiclip to a project (timeline) and expand audio components (contextual menu). Viola – the separate audio tracks are now available.
