Activity › Forums › Apple Final Cut Pro Legacy › Multiclip audio
  • Multiclip audio
    Posted by Frederik Ailliet on January 22, 2010 at 4:03 pm
    Hi
    I did some multicam recording of a concert and now i want to make
    a multiclip of so i can “live” mix it.
    I already made the clips sync but now I want the audio of just one track
    used over the entire concert. ( One of the cameras was connected to the PA so this has best audio ).
    It’s also a lot nicer to work when the audio doesn’t change quality everytime you cut…
    I found a tutorial on how to do this in FCP 5 and it says you have to
    get a green window around the camera you want to use the audio from.
    But I can’t find how to do this…
    Any help would be nice !
    Frederik Ailliet replied 16 years, 8 months ago 2 Members · 2 Replies
  • Rob Wilson
    January 22, 2010 at 6:52 pm
    Ope up your multi-clip in the viewer. At the top of the viewer window there is a small button that looks similar to this |x|
    Within the drop down menu will be the options
    Video + Audio
    Video
    Audio
    Select the ‘Video’ option and your audio will now not change when you make a cut.
    Hope this helps
    Rob
  • Frederik Ailliet
    January 24, 2010 at 3:59 pm
    Thanks.
    Somehow I found a way to do it 🙂
